Structural Design
Walls and Floors
Create Walls
: Create User Defined Wall
Creates a User Defined Wall (GWALL, a soft type element of a Panel (PANE), used to represent a cross-section (usually horizontal) which is extruded (usually vertically) to represent, for example a structural column.
You can create a set of vertices in a number of ways, specific to other attributes necessary to relate these vertices to a 3D representation.
Floors, Screeds and User Defined Walls (GWALL) are soft types of panel, and are created from the same window. In the latter case, the thickness of the panel is equivalent to the height of the user-defined wall.
Refer to
Create Floor
for further information.
