The Circle Definition part of the
Ring Wall window, defines whether the wall is a full circle or a semi circle.
You must set the radius of the new ring wall, by default the radius is 1000.00mm. From the Settings part of the
Create Wall (Ring) window, input the required radius for the wall in the
Radius field.
From the Angles part of the
Create Wall (Ring) window, set the angles for the start and finish positions of the wall segment (between 0 and 360). By default, the start angle is 0 and the end angle is 180. Then click
Anti-clockwise or
Clockwise.
Click Apply to create the ring wall, the wall displays in the 3D view and in the Model Explorer.
Or click Dismiss to discard information and close the
Create Wall (Ring) window.
