Single - Start and end points are individually defined for each section.
Continuous - Start point of subsequent walls is the end point of previous.
Radial - Start point for subsequent walls is the same as the first.
From the drop down menu, click to identify the direction of the East/West axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the North/South axis. The user can then input an explicit position value in the Position field.
From the drop down menu, click to identify the direction of the Up/Down axis. The user can then input an explicit position value in the Position field.
