If you change any of the internal mapping files, you must reload the Model user interface from macros. Alternatively you can use the Re-initialise menu option on the main SDNF Import and Export windows. You should then resave the binary UI.
The first part of this identifier text is either the three-letter name of the project, for example, TST for the TST000 project, or ANY, signifying a companywide table for any AVEVA project.
There is no Model value before the asterisk. For unset CTYA values Default Connection is mapped into the output file.
