Structural Design User Guide
SDNF Export/Import : Technical Information : Linear Member Cutbacks
When the Use Cutbacks check box is left unchecked the start and end positions are the start and end positions of the Justification Pline of the member.
When the Use Cutbacks check box is checked the start and end positions are the positions of the virtual nodes derived from the nodes to which the start/end is connected. The start and end cutbacks are set to the distance between the virtual node position and the Justification Pline position.
When the Use Cutbacks check box is left unchecked the start and end positions of the member are set to the start and end positions. Any cutback values are ignored.
When the Use Cutbacks check box is checked the Start and End positions of the member are trimmed in accordance with the start and end cutback values.
