DRAW
Add and Modify Drawing Objects
Determine Distances, Angles and Points
: Display Point Coordinates
Displays the coordinates of a specified point.
You are prompted to
Specify point
Click to identify the required point.
The context editor and message bar display the coordinates of the selected point.
Input
F
at the prompt and press
Enter
to end the command.
Throughout the display process you can press
ESC
to cancel the command. Additional functionality is also available.
Back
Press the down arrow key and select
Back
to undo the last action.
Finish
Finish
to end the command.
