DRAW User Guide
Add and Modify Drawing Objects : Determine Distances, Angles and Points : Measure Cumulative Lengths of Objects
Input F at the prompt and press Enter to end the command.
Throughout the measuring process you can press ESC to cancel the command. Additional functionality is also available.
