DRAW User Guide
Add and Modify Drawing Objects : Determine Distances, Angles and Points : Measure Distance between two Points
You are prompted to Specify the first point
Input values in the dimension fields and press Enter or click to identify the point to measure from.
You are then prompted to Specify the second point
Input values in the dimension fields and press Enter or click to identify the point to measure to.
Input F at the prompt and press Enter to end the command.
Throughout the angle measuring process you can press ESC to cancel the command. Additional functionality is also available.
