Press the down arrow key and select Select object to begin the fillet process.
Press the down arrow key and select Multiple to fillet multiple objects. Refer to Fillet Multiple Objects for further information.
Press the down arrow key and select Radius to set the fillet arc radius. Refer to Set Fillet Arc Radius for further information.
Press the down arrow key and select Trim to set the trim options. Refer to Turn Trim On/Off for further information.
Press the down arrow key and select Multiple to fillet multiple objects with an arc radius. Refer to Fillet Multiple Objects with Arc Radius for further information.
