DRAW User Guide
Add and Modify Drawing Objects : Modify Drawing Objects : Trim and Extend Objects
You are prompted to Select borders for trim
You are then prompted to Select entity to trim or <Finish>
Input F at the prompt and press Enter to end the command.
Throughout the trim process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Crossing to select objects using a selection box.
Press the down arrow key and select Edge to trim objects to extrapolated edges. Refer to Trim Objects to Extrapolated Edges for further information.
Press the down arrow key and select Delete to delete an object.
Input E at the prompt and press Enter.
You are then prompted to Enter an implied edge extension mode <Extend>
Input E at the prompt or Enter.
Press the down arrow key and select Extend to trim objects to extrapolated edges.
Press the down arrow key and select No extend to trim objects to intersecting objects. Refer to Trim Objects to Intersecting Objects for further information.
You are prompted to Select borders for extend
You are then prompted to Select entity to extend or <Finish>
Throughout the extend process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Edge to extend objects to extrapolated edges. Refer to Extend Objects to Extrapolated Edges for further information.
Press the down arrow key and select Extend to extend objects to extrapolated edges.
Press the down arrow key and select No extend to extend objects to intersecting objects. Refer to Extend Objects to Intersecting Objects for further information.
