DRAW User Guide
Add and Modify Drawing Objects : Modify Drawing Objects : Explode and Merge Objects
You are prompted to Select objects to explode
You are prompted to Select objects to merge
You are prompted to Select option <Finish>
Input F at the prompt and press Enter to end the command.
Throughout the merge process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Close to link the two endpoints of the merged object with an automatically drawn line and end the command.
Press the down arrow key and select Open to merge the objects, the two endpoints of the merged object are unchanged.
