DRAW User Guide
Add and Modify Drawing Objects : Modify Drawing Objects : Scale Objects
You are prompted to Select objects to scale
You are then prompted to Specify base point or
Input values in the dimension fields and press Enter or click to identify the relative base point to which the objects are scaled.
You are then prompted to Specify scale factor or <#>
Input a value in the field and press Enter or click to identify scale factor. The further the cursor is moved from the base point, the larger the objects become.
Throughout the scaling process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Copy to change the size of objects and keep a copy of the original.
Press the down arrow key and select Reference to specify a reference distance. Refer to Change Size of Objects Using Reference Distance for further information.
Input R at the prompt and press Enter.
You are then prompted to Specify reference length or <#mm>
Input a dimensional value in the field and press Enter or click to identify two points that define the reference length.
You are then prompted to Specify new length or
Press Enter to scale the objects using the specified reference length or input a dimensional value in the field and press Enter to scale the objects using the new reference length.
Press the down arrow key and select Points to redefine the reference length points.
