DRAW User Guide
Add and Modify Drawing Objects : Modify Drawing Objects : Mirror Objects
You are prompted to Select objects to mirror
You are then prompted to Specify the first point or
Input values in the dimension fields and press Enter or click to identify the point around which the objects are mirrored.
You are then prompted to Specify the second point or
Input values in the dimension fields and press Enter or click to specify the location of the mirrored objects.
Throughout the mirroring process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Object to re-select the objects to mirror.
Press the down arrow key and select No-copy to mirror the selected objects without keeping a copy of the original.
