DRAW User Guide
Add and Modify Drawing Objects : Modify Drawing Objects : Rotate Objects
You are prompted to Select objects to rotate
You are then prompted to Specify base point or
You are then prompted to Specify rotation angle or <#deg>
Input an angular value in the field and press Enter or click to identify the rotation angle. The objects are rotated and the command ends automatically.
Throughout the rotation process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Copy to create a copy of the rotated objects.
Press the down arrow key and select Base angle to rotate objects around a specified base angle. Refer to Rotate Objects around Base Angle for further information.
Input values in the dimension fields and press Enter or click to identify the point around which the objects are rotated.
Input B at the prompt and press Enter.
You are then prompted to Specify base angle from X axis or
Input an angular value in the field and press Enter or click to identify the base angle with reference to the X axis.
Input an angular value in the field and press Enter or click to identify the rotation angle of the objects.
Press the down arrow key and select Base angle to specify the base angle of the objects.
