DRAW
Add and Modify Drawing Objects
: Paste Objects
Paste Objects
Pastes a selected object.
Objects can be pasted using the following methods:
Paste Objects at specified Insertion Point
Paste Object with Original Coordinates
Pastes objects from the clipboard to a specified position on the drawing canvas.
You are prompted to
Specify insertion point or <Finish>
Input values in the dimension fields and press
Enter
or click to identify the base point relative to which the objects are pasted.
The objects are pasted to the identified position from the clipboard.
The prompt is repeated, allowing you to paste multiple copies of the objects from the clipboard.
Input
F
at the prompt and press
Enter
to end the command.
Paste objects from the clipboard to the same coordinate location on a different sheet/view.
