Press the down arrow key and select Displacement to copy the objects relative to the zero point of the user coordinate system. Refer to Copy and Paste Objects using Displacement Position for further information.
Press the down arrow key and select Mode to specify the copy mode.
You are prompted to Specify copy mode option
Input S at the prompt and press Enter to create a single copy of the objects or input M at the prompt and press Enter to create multiple copies of the objects.
Press the down arrow key and select Single to create a single copy of the objects.
Press the down arrow key and select Multiple to create multiple copies of the objects.
