Press the down arrow key and select Displacement to move the objects, relative to the zero point of the user coordinate system. Refer to Move Objects using Displacement Position for further information.
Press the down arrow key and select Copy to create a copy of the original objects.
Press the down arrow key and select Base as displacement to move the objects the distance measured from the zero point of the user coordinate system.
