DRAW User Guide
Add and Modify Drawing Objects : Modify Drawing Objects : Modify Objects using Grip Points
You are prompted to Specify stretch point
Input the distance to move the endpoint at the prompt and press Enter or click to identify the endpoint position.
Alternatively, you are prompted to Specify Angle. Input the sweep angle at the prompt and press Enter.
