Press the down arrow and select Fillet radius to specify the fillet radius of the triangle. Refer to Draw Equilateral Triangle with Specified Vertices and Set Fillet Radius for further information.
Press the down arrow key and select Centre mode to draw a triangle with a specified centre point. Refer to Draw Equilateral Triangle with Specified Centre Point for further information.
Press the down arrow key and select Fillet radius to specify the fillet radius of the triangle. Refer to Draw Equilateral Triangle with Specified Centre Point and Set Fillet Radius for further information.
Press the down arrow key and select Vertex mode to draw a triangle with specified vertices. Refer to Draw Equilateral Triangle with Specified Vertices for further information.
Press the down arrow key and select Vertex to draw a triangle with specified vertices. Refer to Draw Equilateral Triangle with Specified Vertices for further information.
