Press the down arrow key and select Circumference to draw a circle with a specified circumference. Refer to Draw Circle with Two Specified Points for further information.
Press the down arrow key and select Diameter to draw a circle with a specified diameter. Refer to Draw Circle with Specified Diameter for further information.
Press the down arrow key and select Change reference point to specify a radius distance or reference point. Refer to Draw Circle with Specified Radius using a Distance or Reference Point for further information.
Press the down arrow key and select Centre to draw a circle with a specified radius. Refer to Draw Circle with Specified Radius for further information.
Press the down arrow key and select Radius to draw a circle with a specified radius. Refer to Draw Circle with Specified Radius for further information.
Press the down arrow key and select Change reference point to specify a diameter distance or reference point. Refer to Draw Circle with Specified Diameter using a Distance or Reference Point for further information.
