Press the down arrow key and select Hor to add horizontal XLines. Refer to Add Horizontal XLines for further information.
Press the down arrow key and select Ver to add vertical XLines. Refer to Add Vertical XLines for further information.
Press the down arrow key and select Ang to add XLines by specifying the angle. Refer to Add XLines with a Specified Angle for further information.
Press the down arrow key and select Bisect to add bisecting XLines. Refer to Add Bisect XLines for further information.
Press the down arrow key and select Undo to undo the last action.
Press the down arrow key and select Main to add a different XLine type. Refer to Add XLines for further information.
Press the down arrow key and select Reference to select a line object to act as a reference for specifying the angle. Refer to Add XLines with a Reference Line to Specify an Angle for further information.
