Input values in the dimension fields and press Enter or click to identify the first corner of the region.
Input values in the dimension fields and press Enter or click to identify the opposite corner of the region.
Throughout the region creation process you can press ESC to cancel the command. Additional functionality is also available.
Input values in the dimension fields and press Enter or click to identify the centre point of the region.
Input a dimensional value in the field and press Enter or move the cursor left or right to define the width of the region. Click to confirm the required width.
Input a dimensional value in the field and press Enter or move the cursor up or down to define the height of the region. Click to confirm the required height.
Throughout the region creation process the you can press ESC to cancel the command. Additional functionality is also available.
