DRAW User Guide
Create and Modify Views : Format 2D View : Create and Apply Local Hatching Rules
Click OK to add the rule to the Rules list or Cancel to discard any changes and close the Create HRUL window.
Select the Menus option button and select the elements the rule is applied to from the drop-down list.
Select the Names option button and click Modify to display the Names window. Refer to Names for further information.
To apply qualifying restrictions to the elements specified in the For section, input an expression in the With field. For example, if the For section specifies Branches, the following can be input:
Click Apply to apply the hatching rules or Cancel to discard any changes and close the Local Hatching Rules window.
Select only sectioned surfaces from the drop-down list to specify that only surfaces cut by a section plane are considered.
Select all primitive surfaces from the drop-down list to specify that the element need not be cut by a section plane to be considered.
Allows you to view the Hatching Rule Attributes Plot window which illustrates the hatching rule attributes. Refer to Hatching Rule Attributes Plot for further information.
Select the All surfaces in all directions option button to specify that all surfaces meeting the criteria in the Consider list are hatched.
Select the Only surfaces perpendicular to view direction option button to specify that only those surfaces perpendicular to the view are hatched. For example, if the view direction is north, the south face of the element is hatched, assuming it meets the criteria in the Consider list.
Select the Only surfaces facing in the specified direction option button to specify a direction normal to the surface to be hatched, instead of using the view direction. For example if a box displays in an isometric view with the top surface crosshatched and six surfaces of a box are required to have different hatching styles, this option would be used on six Hatching Rules.
The functionality is only available when the Only surfaces facing in the specified direction option button is selected.
Click to select a design element. The Direction (Y) window displays. Refer to Direction for further information.
Click Apply to apply the hatching rules or Cancel to discard any changes and close the Local Hatching Rules Attributes window.
You are prompted to Identify Design element for Derived Direction
The General drop-down menu allows you to define the direction from the CE or the owning element of the CE in the hierarchy.
The Cursor drop-down menu allows you to define the direction from an element, design point or Pline.
You are prompted to Identify Element
You are prompted to Identify Design Point
You are prompted to Identify Pline
The Intersection drop-down menu allows you to define the direction from two items using a cursor pick.
The Points drop-down menu allows you to select three elements or design points on the drawing canvas to define the direction.
Click Apply to set the defined direction or Dismiss to discard any changes and close the Direction (Y) window.
