Allows you to create a rule. Click to display the Create RRUL window.
Input a name for the new rule in the Name field.
Click OK to add the rule to the Rules list or Cancel to discard any changes and close the Create RRUL window.
Select the All option button and select the elements the rule is applied to from the drop-down list.
Select the Names option button and click Modify to display the Names window. Refer to Names for further information.
To apply qualifying restrictions to the elements specified in the For section, input an expression in the With field. For example, if the For section specifies Branches, the following can be input:
Select Element to navigate to the first element in the currently selected hierarchy. The element is selected in the Members List.
Select Member to navigate to the first member of the currently selected element. The element is selected in the Members List.
Select Element to navigate to the last element in the currently selected hierarchy. The element is selected in the Members List.
Select Member to navigate to the last member of the currently selected element. The element is selected in the Members List.
Select Design Members from the drop-down list to pick design elements explicitly.
Select Drawlists from the drop-down list to identify design elements by their presence in other drawlists.
