Select By Style from the drop-down list to inherit the annotation offset position from the selected visual style.
Select Yes from the drop-down list to position the annotation offset from the attached gridline p-point.
Select No from the drop-down list to position the annotations offset from the view frame.
Select By Style from the drop-down list to inherit the annotation offset distance from the selected visual style.
Select By Style from the drop-down list to inherit the dimension offset distance from the selected visual style.
Select By Style from the drop-down list to inherit the annotation closing dimension settings from the selected visual style.
Select No from the drop-down list to define that dimension lines from the view frame to the first and last gridline do not display.
Select Yes from the drop-down list to display dimension lines from the view frame to the first and last gridline.
Select By Style from the drop-down list to inherit the annotation overall dimension settings from the selected visual style.
Select No from the drop-down list to define that overall dimension lines from the first to last gridline do not display.
Select Yes from the drop-down list to display overall dimension lines from the first to last gridline.
Select By Style from the drop-down list to inherit the overall dimension offset distance from the selected visual style.
Select By Style from the drop-down list to inherit the vertical dimension settings from the selected visual style.
Select No from the drop-down list to define that vertical dimension lines between the elevation gridlines do not display.
Select Yes from the drop-down list to display vertical dimension lines between the elevation gridlines
For an orthogonal view, you can define the annotation display for Top, Bottom, Left, Right, None, All.
For example, input Right Bottom to display reference grid annotations on the right and bottom of the view.
For a non-orthogonal view, you can define the annotation display for Left, TopLeft, TopRight, Right, BottomRight, BottomLeft, None, All.
For example, input Right Bottom BottomLeft BottomRight to display reference grid annotations on the right, bottom, bottom left and bottom right of the view.
Select Off from the drop-down list to define that reference grid annotations do not display.
Select Labels from the drop-down list to display only labels.
Select Dimensions from the drop-down list to display only dimensions.
Select All from the drop-down list to display both labels and dimensions
Select By Style from the drop-down list to inherit the reference grid annotation settings from the selected visual style.
Click to display the Select window.
Click Select to apply the selected template.
The functionality of the Elev label template is identical to the Face label template field. Refer to Face label template for further information.
