DRAW
Create and Modify Views
Format 2D View
: Apply Cutting List to Section Plane
Each section plane can be associated with a pre-defined cutting list. Elements within the cutting list are removed from the view, allowing for other elements to remain in the view even though a section plane exists.
Cutting lists, which are effectively drawlists, are pre-defined by the administrator.
Select a cutting list from the
Select Cutting List
drop-down list.
Click
Pick Section Plane
to associate a cutting list with a section plane.
You are prompted to
Select section
Click to identify the section plane to associate with the cutting list.
The prompt is repeated allowing you to associate multiple section planes with the cutting list.
Press
ESC
to end the command. The cutting list is associated with the identified section planes.
When the cutting list associations are complete. It may be necessary to manually update the view to display the modifications. Refer to
Current Owner
for further information.
The example indicates a view that contains piping and equipment elements. The piping elements are contained within the cutting list and removed from the view using a section plane. The equipment elements are ignored by the section plane and remain within the view.
