Press the down arrow key and select Perpendicular to create a perpendicular section plane. Refer to Create 2D Perpendicular Section Plane for further information.
Press the down arrow key and select Flat to create a flat section plane. Refer to Create 2D Flat Section Plane for further information.
Press the down arrow key and select View to create a section plane using a specified view projection. Refer to Create Section Plane on View Projection for further information.
Press the down arrow key and select Side to define which side of the section plane displays in the view. A shaded area indicates the side of the section plane that an area of the view is removed from.
Press the down arrow key and select Close to create a closed section plane.
Press the down arrow key and select Open to create an open ended section plane by moving the cursor across the view.
Press the down arrow key and select Stepped to create a stepped section plane. Refer to Create 2D Stepped Section Plane for further information.
Press the down arrow key and select Perpendicular to create a perpendicular section plane. Refer to Create 2D Perpendicular Section Plane view for further information.
Press the down arrow key and select Stepped to create a stepped section plane. Refer to Create Stepped Section View for further information.
Press the down arrow key and select Horizontal to define a horizontal area to be removed from the view.
Press the down arrow key and select Vertical to define a vertical area to be removed from the view.
Press the down arrow key and select Angle to specify an angle to define the area to be removed from the view.
