Select Outline from the drop down list to display an outline view of the hull.
Select Detailed from the drop down list to display a detailed view of the hull.
Select Yes from the drop-down list to display cableway elements in the view.
Select No from the drop-down list to remove cableway elements from the view.
Select Yes from the drop-down list to display equipment elements in the view.
Select No from the drop-down list to remove equipment elements from the view.
Select Yes from the drop-down list to display piping elements in the view.
Select No from the drop-down list to remove piping elements from the view.
Select Yes from the drop-down list to display room design elements in the view.
Select No from the drop-down list to remove room design elements from the view.
Select Yes from the drop-down list to display structural elements in the view.
Select No from the drop-down list to remove structural elements from the view.
Select Yes from the drop-down list to display HVAC elements in the view.
Select No from the drop-down list to remove HVAC elements from the view.
Select Yes from the drop-down list to display reference surface objects in the view.
Select No from the drop-down list to remove reference surface objects from the view.
