The default element is Sheet for a drawing sheet, the default element is Symbol Template for a symbol template.
The view only field displays the projected picture size, on the X axis, when the Scale Factor is added.
The view only field displays the projected picture size, on the Y axis, when the Scale Factor is added.
Select the check box to overwrite the original picture size. The Paper Format drop-down list, Size X and Size Y fields become active.
