Certain attributes of a drawing, for example, its size and backing sheet (if set), are inherited as the default attributes of sheets created for that drawing. These can be changed if required, for example, with the Properties window. In turn, attributes set for a sheet are inherited as the default attributes of the views of that sheet.
