DRAW User Guide
Create Drawing Sheets and Support Elements : Modify Department Attributes : Miscellaneous
The Miscellaneous tab on the Department Attributes window allows you to define a number of department attributes.
Click Reset to revert to the values applied when the Department Attributes window was opened.
Click Apply to modify the department attributes or Cancel to discard any changes and close the Department Attributes window.
