DRAW User Guide
Create Drawing Sheets and Support Elements : Create Departments, Registries and Drawings : Create Drawing from Drawing Type and Template
Select Drawing from the available Drawing Types.
Select a Template Type from the drop-down list to filter the available Templates. The appearance of the templates is pre-defined by the administrator allowing for the production of company standard drawings.
Click Create to display the Create Drawing window.
The Create Drawing window is very similar to the Hierarchy Browser window. Refer to Create Departments, Registries and Drawings with the Hierarchy Browser Window or Open Window.
You can browse the hierarchy to select the registry that the drawing is to be created in. Either input a name in the Name field, or leave it blank if the drawing is to be assigned a default name.
Click Create to create the drawing or Cancel to discard any inputs and close the Create Drawing window
