DRAW User Guide
Create Drawing Sheets and Support Elements : Create Departments, Registries and Drawings : Create and Modify Registries
The Create REGI window displays a default name for the element followed by the next available number, for example, REGI3. Input a different name if required.
Click OK to apply the REGI name or Cancel to discard any changes and close the Create REGI window. By default, the Registry Information window displays.
Select the Create Drawing check box to create a DRWG element below the REGI element, by default. Refer to Create Drawing for further information.
Click Attributes to display the Registry Attributes window, which allows you to define the default attributes for the registry. Refer to Modify Registry Attributes for further information.
Click OK to create the REGI element or Cancel to discard any changes and close the Registry Information window.
