The Create DEPT window displays a default name for the element followed by the next available number, for example,
DEPT2. Input a different name if required.
Click OK to apply the DEPT name or
Cancel to discard any changes and close the
Create DEPT window. By default, the
Department Information window displays.
Select the Create Registry check box to create a REGI element below the DEPT element, by default. Refer to
Create Registry for further information.
Click Attributes to display the
Department Attributes window, which allows you to define the default attributes for the department. Refer to
Modify Department Attributes for further information.
Click OK to create the DEPT element or
Department Information window.
