DRAW User Guide
Basic Operations : Power Selector
Select Primitive from the drop-down list to select primitive elements using primitive filter criteria. Refer to Primitive Selection for further information.
Select Annotation from the drop-down list to select label or dimension elements using annotation filter criteria. Refer to Annotation Selection for further information.
Select All from the drop-down list to filter the selection of all elements on the current sheet.
Select Current Owner from the drop-down list to filter the selection of all elements that you currently own.
Click to select all elements that match the filter criteria, the Collections window displays. Refer to Collections for further information.
Select All from the drop-down list to filter the selection of all primitives.
Select the Label tab to filter the selection of all labels.
Select the Dimensions tab to filter the selection of all dimensions.
Select Element name from the drop-down list to filter the selection of labels or dimensions using the name of an element based on an intelligent link to the AVEVA E3D™ model.
Select Element type from the drop-down list to filter the selection of labels or dimensions using the type of element based on an intelligent link to the AVEVA E3D™ model.
You are prompted to Select design element or Select entity
