DRAW
Basic Operations
Select View
: Tab Groups
Tab Groups
If more than one drawing is open, DRAW displays each drawing in the view as a tab (provided that Tabbed View is the current view format, refer to
Tabbed View
for further information). You can click a tab to display the drawing in the view.
The tab view of open drawings can be grouped to display the drawings in a split horizontal or vertical window.
To create a new horizontal tab group, right-click the drawing tab to be viewed in a split window and select
New Horizontal Tab Group
from the drop-down list.
The drawing tab displays in a split window and a tab group is created.
To create a new vertical tab group, right-click the drawing tab to be viewed in a split window and select
New Vertical Tab Group
When tab groups are created, you can move drawing tabs from one tab group to another.
To move an existing drawing tab to a newer horizontal or vertical tab group, right-click the drawing tab to be moved and select
Move to Next Tab Group
To move an existing drawing tab to a previous horizontal or vertical tab group, right-click the drawing tab to be moved and select
Move to Previous Tab Group
