DRAW
User Interface
: Active Properties
Active Properties
Displays the default properties that are applied to new objects when they are created and subsequently applies the properties to selected objects, if required.
The current active properties display and can be modified. When a new object is created, these properties are automatically applied to that object.
To apply the current properties to an object, select the check boxes for those properties to be applied, and select a property from the drop-down list.
Pick the selected entity properties and select them as current
Click to set the selected properties as the active properties. If multiple objects are selected they must have the same properties.
Apply the current setting to the selected entities
Click to apply the active properties to a selected object using a cursor pick.
