The Search part of the Isometric Drawings Search window allows you to define the search criteria for the drawing search.
Input a value in the Search field and select a filter from the
Search drop-down list to define the search criteria. For example, Input
APS in the field and select
Drwg Name from the drop-down list to display all drawings that contain APS in the drawing name.
Click Go to populate the
Drawings part of the
Isometric Drawings Search window with the search results.
The Drawings part of the
Isometric Drawings Search window displays the results from the drawings search. You can modify the Drawings list display. Functionality is also available to open, print and export drawing sheets.
