On the Tasks part of the
Isometric Production window, click
Modify User Settings, to populate the
Isometric Production window with the user settings.
        On the Locations part of the
Isometric Production window, input another location in the
Create Isometrics in this Registry field or click
Browse Registries.
        The Browse window displays all available rewritable registries.
        To select a registry, select a database from the Look in drop-down list. All registries that the you can write to are listed. Select the registry where drawings are to be located.
        Click Use to apply the registry location setting or
Cancel to discard any inputs and close the
Browse window.
        You must also select the level of complexity from the with complexity drop-down list, which affects the number of spools created and the number of drawings produced.
        You can check the effect of changing the complexity using a Spool Preview, refer to Preview Spooling for further information. If the
Preview Spooling window is open when the splitting method is changed, the 3D view is updated, by default.
        The administrator sets the default Look Direction for all Isometric drawings, but in some cases this is not suitable for a particular branch. Select the relevant North Direction check box to change the look direction when the drawings are produced. If the
Preview Spooling window is open, the view changes to suit the new
North Direction.
        The values for each of the Issue Types are set by the administrator, the default being Alphabetical for Internal Issues and Numeric for External Issues.
        The Output part of the
Isometric Production window allows you to define the location of the Excel file and the PDF output.
        When any of the Isometric ADP settings are changed, the title of the Settings part of the
Isometric Production window changes to
Settings* indicating that one or more settings values have changed.
        Click Save to save all changed settings. On re-entry to the module at a later time, the settings are reloaded, by default.
