Click to refresh the search results when the search criteria is changed if the Track current element check box is not selected. If required, select the
Track current element check box to track element selection in the Model Explorer, refer to
Track Current Element for further information.
The Search for: drop-down menu allows you to define the element type to search. You can search for
CWAY or
HVAC design elements.
The Filter the results for: drop-down list allows you to filter the search results.
The Scope part of the
Advanced Search for Ducting and
Advanced search for Cable Tray windows allows you to define the scope of the search.
The Find elements that have part of the
Advanced Search for Ducting or
Advanced search for Cable Tray windows allows you to define advanced search criteria.
