Select Export to multiple files from the drop-down list to export multiple sheets to individual files. By default, each exported file is named using the sheet name.
Select Export to single file from the drop-down list to export multiple sheets to single file. By default, the export file is auto named.
Refer to Export Multiple Sheets for further information.
Select Export to SVG/AVEVA.NET from the drop-down list to define a .SVG file that is suitable for AVEVA.NET as the export format.
Click to define the settings for the export. Refer to SVG/AVEVA NET Export Settings for further information.
Select Draw from the drop-down list to export a SVG/AVEVA.NET file that contains CAD configurations.
Select Reports from the drop-down list to export a SVG/AVEVA.NET file that does not contain CAD configurations.
Select the check box to create a log file (.txt file) when the export is processed. The Log File field becomes active.
If Draw is selected from the Name drop-down list, a SVG/AVEVA.NET file is exported that contains CAD configurations. Refer to CAD Configuration Settings for further information.
If Reports is selected from the Name drop-down list, a SVG/AVEVA.NET file is exported that does not contain CAD configurations. Refer to Non-CAD Configuration Settings for further information.
Alternatively, select RGB values from the drop-down lists to define a custom background colour for the export file.
Alternatively, click Pick Colour to display the Color window. The functionality of the Color window is explained as part of the process to modify the DRAW Display Options. Refer to Colours for further information.
