DRAW User Guide
Output Facilities : Export to PDF
When Export is selected, the current export settings are saved.
Select Export to multiple files from the drop-down list to export multiple sheets to individual files. By default, each exported file is named using the sheet name.
Select Export to single file from the drop-down list to export multiple sheets to single file. By default, the export file is auto named.
Refer to Export Multiple Sheets for further information.
Select Export to PDF from the drop-down list to define a .PDF file as the export format.
Select Default from the drop-down list, the colour, fill and line style settings are not changed.
Select Monochrome from the drop-down list to export all colours as black and white.
Select Greyscale from the drop-down list to export all colours as greyscale.
Select Sheet from the drop-down list to export the currently selected sheet.
Select Display from the drop-down list to export the current display area of a sheet.
Select Extents from the drop-down list to export the extents of a sheet.
Select Window from the drop-down list to export a display area defined by you. Click Specify window to define the display area to be exported.
You are prompted to Specify first corner
You are then prompted to Specify opposite corner
Select Landscape Orientation to export the sheet as Landscape.
Select Landscape Upside Down Orientation to export the sheet as Landscape Upside Down.
Select Portrait Orientation to export the sheet as Portrait.
Alternatively, you can de-select the check box and input coordinates in the X and Y fields to define the centre point of the exported area.
