Press the down arrow key and select Vertical to align labels vertically.
Press the down arrow key and select Horizontal to align labels horizontally.
Press the down arrow key and select Standard to align labels with the angle of the leader lines preserved.
Press the down arrow key and select Extend to align labels with the angle of the leader lines preserved.
Only labels can be aligned in extended mode. The Connection point offset field in the Properties window must be set to Origin. Refer to Properties for further information.
