If no element has been selected, you are prompted to select an element before the Intelligent Label Placement window displays.
You are prompted to Select Element
Click to display the Point Construction Option Form window.
You are prompted to Input 2 point(s) on a sheet
Select the check box and click Definition to display the Remote Label Placement window. Refer to Remote Label Placement for further information.
Select the check box and click Definition to display the Local Label Placement window. Refer to Local Label Placement for further information.
The Point Construction Option Form window displays.
