               Press the down arrow key and select Glyph to select a different symbol for the marker point. Refer to Add Marker Point with Specified Glyph for further information.
               Press the down arrow key and select Size to specify a different size for the marker point.
               Press the down arrow key and select Insert to add the marker point to the drawing. Refer to Add Marker Points for further information.
