DRAW User Guide
Add Annotation : Add Marker Points : Add Marker Point with Specified Glyph
You are prompted to Specify the insertion point or <Finish>
Input G at the prompt and press Enter to display the Glyph Selection window.
By default, the Glyph Selection window closes and you are prompted to Specify the insertion point or <Finish>
Input values in the dimension fields and press Enter or click to identify the insertion point for the marker. The marker point is added to the drawing.
Input F at the prompt and press Enter to end the command.
Throughout the process of adding marker points to the drawing you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Glyph to select a different symbol for the marker point.
Press the down arrow key and select Size to specify the size of the marker point. Refer to Add Marker Point with Specified Size for further information.
Press the down arrow key and select Insert to add the marker point to the drawing. Refer to Add Marker Points for further information.
