Press the down arrow key and select Mode to specify the pitch circle dimension mode.
You are prompted to Specify dim mode <Diameter>
Press the down arrow key and select Style to specify the pitch circle dimension style.
You are prompted to Specify dim style <dim line>
Press the down arrow key and select Angle mode to specify the pitch circle dimension angle mode.
You are prompted to Specify angle mode <Free>
Press the down arrow key and select Design item to specify a design item to annotate.
You are prompted to Select design object.
