Projection Line text can be modified in the same way, you must input a rotation angle in the Proj line text rotation angle field of the Properties window. By default, the value in the Dim line text angle field is populated with Custom.
Projection Line text can be modified in the same way, you must input a rotation angle in the Proj line text rotation angle field of the Vertex Editor window. By default, the value in the Dim line text angle field is populated with Custom.
