DRAW User Guide
Add Annotation : Dimensions : Define Dimension Project Line Overshoot and Clearance Length using Grip Points
To display the grip points, make sure that Additional grips on/off is highlighted on the status bar. Refer to Status Bar for further information.
You are prompted to Specify stretch point
Input a dimensional value in the field and press Enter or click to identify the overshoot or clearance length.
The overshoot property can also be modified using the Projection line field on the Properties window. Refer to Properties for further information.
