Press the down arrow key and select Type to specify the type of angular dimension.
Press the down arrow key and select Sense mode to specify the mode of the angular dimension. Refer to Sense Mode for further information.
Press the down arrow key and select Derived to define the origin point of the angular dimension using the intersecting point of two P-lines. Refer Add Angular Dimensions with Derived Intersection to for further information.
Press the down arrow key and select Chained to specify the angular dimension type as chained.
Press the down arrow key and select Baseline to specify the angular dimension type as angular baseline.
Press the down arrow key and select Combined to specify the angular dimension type as combined.
Press the down arrow key and select Direction to add angular dimensions with a specified direction. Refer to Add Angular Dimensions with Specified Direction for further information.
Press the down arrow key and select Free to create the angular dimensions in either a clockwise or anti clockwise rotational direction style. The style is defined by the cursor movement direction used to create the dimension points. Refer to Sense Mode for further information.
Press the down arrow key and select By style to create the angular dimensions using the rotational direction style used to create the previous angular dimension. Refer to Sense Mode for further information.
You are prompted to Select option <Chained>
You are prompted to Specify sense mode <Free>
Press the down arrow key and select Position to add angular dimensions with a specified position. Refer to Add Angular Dimensions for further information.
